Daves 71 NH Build
dave67fd
dave67fd
Well I guess I'm way overdue on getting some progress posted but trying to get myself motivated to try and start hitting this a bit harder.
Hitting the smaller stuff for now and awaiting some more sheet metal parts.
This is the passenger rear inner fender repair.
hankjr
Perfect Dave. Just keep banging away like that!
Hank
dave67fd
dave67fd
This is the rear filler neck repair. Old is cut out and new is fitted awaiting reweld and driver outer rocker is out.
fatboy
Glad to be here.
New Hampshire
Looking good Dave! I have a plasma cutter if you want to borrow it to cut patch panels out of the flat stock you have.
tasker
all knowing of nothing
NH
Gotta see it at next years event!! Keep after it Dave!!
migs
nice job Dave! keep picking away, it'll be done before you know it.
dave67fd
dave67fd
Thanks all...Hoping not to cut too many more custom pieces but will let ya know Pete thanks.
Master Chief
Eww! That rocker...I think I just puked a little bit. Probably happy to cut that crap out. Keep that up and you'll have a shiny new Bronco in no time.
dave67fd
dave67fd
A Belated thanks guys.
Did a repair on the passenger rear wheel well to extension panel.
Have a high weld area I still want to hit a litle bit more but came out acceptable.
Also put together a couple of cowl supports. Nice to repurpose the crappy Aero tank brackets.;D
Slednut10
Guru? That's funny!
I'm seeing far more patience and talent than you give yourself credit for. Good to see ya back at it!
Pa PITT
Stephenville TEXAS
DAVE What are you spraying on your finished repairs.
NO I DID NOT READ every page to see what your using.
But it looks good over your repairs..
Nice work..
dave67fd
dave67fd
Nice work..
Thanks Pa,
I'm using Eastwood's Self etching weld thru primer.
http://www.eastwood.com/eastwood-self-etch-primer-gray.html
Looking good D!
NICE job Dave!! looking real good!!
Ditto here.. making good progress
Thanks for the all the nice comments guys..Much appreciated.
dave67fd
dave67fd
Little more progress.
Blasted the E-brake assy and accelerator pedal over the winter and just got to priming/painting recently.
Pulled the passenger outer and inner rockers.
Too deep in to turn back now.%);D
dave67fd
dave67fd
Anybody know where to purchase this piece? Haven't seen them around.
I can repurpose if needed just figured be cheaper to just buy one if available.
I believe it's the passenger seat or lap belt support bolt/bracket.
