Daves 71 NH Build
Slednut10
Guru? That's funny!
Way to go buddy. I can only imagine how good the body will be after seeing that piece of artwork! (no pun intended%))
hankjr
Box looks great. Mine is all cleaned and painted but in pieces on the pool table next to speedo head patiently waiting for the end of ski season.
Hank
Miker
Just got caught up Dave with the thread. Looking' great and steady wins the race!
dave67fd
dave67fd
Well not much work done since the Heater box rebuild but did strip the tailgate parts. Did a pre assesment of the tub.%)
Starting to seriously think of the Fiberglass Tub route. Not too scared of the work just scared of how long it will take.:-[
I didn't even bother taking pics of the entire cowl assy..%) and sure I missed a few other things.
Opinions much appreciated.
1) Passenger rear body Mount repair.
2) Passenger rear Taillight Inner/Lower to Inner Fender repair.
3) Passenger rear Wheel well Tub to wheel house extension repair.
4) Passenger rear Inner Fender repair (PO cut)
5) Driver rear Filler Neck Extension Panel replace.
6) Driver rear lower Quarter Panel replace.
7) Driver rear Bottom Taillight Housing repair
8) Driver rear Door Striker Brace replace.
9) Passenger front (RH) Wheel House Extension replace.
10) Passenger front (RH) Rail Support Bracket replace.
11) Passenger Rear Door Striker Brace replace.
12) Passenger Rear Door Post replace.
13) Passenger to mid rear floor pan replace.
14) Passenger Inner Rocker panel replace.
15) Driver Inner and Outer Rocker panel replace.
16) Passenger front floor support replace.
17) Passenger and Driver Upper Floor to Cowl Dash panel replace.
18) Driver and Passenger front Floor pan replace.*
19) Complete upper Cowl Assy. Replace.
20) Front RH/LH Inner Fender replace.*
21) Passenger (RH) front Wheel Tub replace.
22) Core support brackets replace.*
23) Inner Kick Panels replace.*
24) Front Driver Door Post replace.
dave67fd
dave67fd
And a few more....
tasker
all knowing of nothing
NH
if you forsake that tub...I want it back! :cool:
Stutsmo
I think you should fix the metal tub. It takes time yes but the work is not that hard and it appears you have a pretty good group of people that might be willing to pitch in and give you a hand. Plus if I was being honest, I have never seen a fiberglass bodied Bronco that has made me step back and say “Wow, I would rather have this than a metal body.” Don’t get me wrong I don’t have anything against fiberglass bodies. I just like the metal ones better.
tasker
NH
that's it! we are through! ;D
NGABronco
Always Learning
N. GA now South Carolina
And that my friends are why we have blondes, brunettes and redheads!!!!;D;D;D
Fix the damn body Dave and go on down the road!!!!:cool::cool::cool:
hankjr
Delaying the inevitable with the body but in the mean time, rebuilt the heater box.
Dave nice job on teh heater box rebuild. im finishing up mine now. what did you use for adhesive for hold foam / gaskets in place? what did you do for gasket on the larger motor?
thx
Hank
hankjr
Also, on the diverter flaps, was your foam oversize? did you have to trim the foam or leave it as is? My foam is a fair amount oversize. Any pics of the flaps with foam installed?
Thx
Hank
fatboy
Glad to be here.
New Hampshire
thx
Hank
Thx
Hank
Hank my foam was oversized and I used spray adhesive for my diverter doors. For the oversized motor I used the gasket that came with it I think and just stretched it over the larger cage. But I was not nearly as particular as you and Dave are since this is going in the yellow truck.
dave67fd
dave67fd
Hey Hank,
Sorry for the late reply.
Pete's spot on. I'm pretty sure the gasket sets that come with these fit several other models as well so the foam is oversized/odd shaped.
Stay tuned, should have some updates to this thread soon.%);D
