decode my engine tag
jamie
289 e 68 16 L27 233-j... i know its a 289 from a 68 bronco, but what are the other numbers for?
tasker
all knowing of nothing
NH
e= enormous horse power
68= year
16= what it wished it got for mileage
L27=lunch time built 2/7
233= how much it weighs bare block
-j= Jamie
am i close????
Jonboy69
Yeah, I have tried online to find this info as well but no luck. Here is the info for mine (based on the id tag I found behind the original coil) if anyone has a codecracker.
Engine Info: 302 C 69 5
9C K296-S
Block Cast: 9C12W
tierra
Torrance Co., NM
From the must-have book: How to Rebuild Your Small-Block Ford, by Tom Monroe, HP Books, 1978 (there are newer editions than my copy).
Jamie's 289 e 68 16 L27 233 decodes to:
289 = Engine C.I.D.
68 = Model Year
16 = Change Level
L27 = Month of Engine Production (7 = 1967, L = November)
233 = Engine Code Number
Jonboy69's 302 C 69 5, 9C K296-S, Block Cast: 9C12W decodes to:
302 = Engine C.I.D.
69 = Model Year
5 = Change Level
9C = Month of Engine Production (9 = 1969, C = March)
296 = Engine Code Number
9C12W = Engine Build Date (March 1969)
Interestingly, Monroe says that the metal tag was used from January 1964 to February 1973. My Bronco was built in January 1973 and still has the tag under the coil bracket. After Feb. 1973, Ford replaced the tags with the decals on the front of the right valve cover. The decals have a different decoding scheme. See Monroe's book for details.
chrlsful
Wow, looks so different to mine. This is for an I6. Block code is near the down tube of exhaust.
C8DE (C = 1960s) 8 =1968 D (ford is NOT model specific) is falcon/Bronco E=engine
