Definitive longer factory ebrake cables
Jfryjfry
I read about 1977 f150 ebrake cables being longer and I read about using a passenger side bronco for the drivers side for lifted broncos.
Well, ours is a 2.5” suspension and a 1” body lift and needed new cables.
I ordered all of those and none really worked well. Not quite long enough, different cable ends, different lengths....
So I spent a couple of hours researching through rock auto’s descriptions that had sheath and cable length looking for a pair that would have the SAME amount of cable longer than the sheath that matched ours. By my measurements, we need about 13” of cable to get into the drum and to reach the lever.
Cutting to the chase, I found that 1972 (70-72 are apparently the same) ford f100 (with the 302 but I don’t know that it makes any difference) has left and right cables that are a few inches longer, the same excess cable length and the correct ball end and same mounting system on both ends as the broncos.
The ONLY part that doesn’t work 100% well is, with new drums and pads, i still ran the adjuster about 75% up to get them adjusted properly. But it isn’t really a problem. They work great, no issues, and if I run out of adjustment later, I can easily space the lever out with some washers between the nut and the union piece.
I got the raybestos cables because I could see the sizes. They were $30 each. They have a doorman brand for about $18 each which should work identically.
Just wanted to share. Pics aren’t the best but they should show how well it all fits.
You could easily route them differently for clearance but ours is, unfortunately, just a city truck.
J
Jfryjfry
On rockauto, the raybestos parts are:
Bc92493
Bc92492
The dorman parts are:
C92493
C92492
(Same part number minus the b)
And yes, my truck has a 3.5” total lift.
It would work with a taller lift as well
But it isn’t so long that I have a lot of excess slop.
I would imagine that these are what the stores sell as extended cables for our rides.
You can see in the first picture how the adjuster is 3/4 of the way adjusted. If/when I use it all, you just remove the nut, add a spacer (stack of washers) and push the union piece further up the shank past the threads. Not a big deal.
johnbeck
Do you happen to know what lengths my 73 would need- it has a 1' body lift but no suspension lift? They need replacement and I have to do the rear brakes soon so I'll be there. Thanks
J
Jfryjfry
Hope this helps - I know it’s been addressed before but that didn’t stop me from spending a long time researching and buying and trying and returning.
Yes, these will work with a 1” lift but you’ll have more excess to route. I don’t know how the stock would work that. It also depends on how much droop you have/will use.
yakelys69
Contributing to the thread.
Some items I've researched for extending the rear center rubber brake hose. I haven't purchased any of these yet.
WAGNER
Stock Bronco:
BH64846
Junction: 2 way 3/8 - 24
Length: 16.73
https://drivcat.com/overlays/part-detail.aspx?brandId=WB&pNum=BH64846&partType=Brake Hose
BH55581
Length: 20.28
BH98947
Length: 23.11
74 Bronco Billy
So, I bought one Dorman (cheaper 18), and one Wagner (expensive 30), and they both work fine, though the Wagner had better fit with gold anodized end and nice spring clip mount. This was on my WH 3.5 SL and WH 1.0 BL. I would definitely use these again
FordBronc
Bronco's, yea I have a couple.
Polk County, Missouri
Maybe some more helpful input?
Cable, front, emergency brake.
Fits 78-79 F250 4WD reg cab, 133" WB.
Cable length 108 1/2" long
D7TZ-2853-C
Wesley Obsolete Parts, Liberty, KY has 78 (606) 787-5293
Dennis Carpenter Obsolete, Concord, NC has 1 (704) 786-8139
Green Sales, Cincinnati, OH has 1, (800) 543-4959
D6TZ-2A635-C .. Right Rear Parking Brake Cable - 57 1/8" long / Obsolete
HAVEN FORD in Haven KS = 620-465-2252.
WESLEY OBSOLETE PARTS in Liberty KY = 606-787-5293.
GREEN SALES CO. in Cincinnati OH = 800-543-4959.
D6TZ-2A635-D .. Left Rear Parking Brake Cable - 65 3/4" long / Obsolete
HAVEN FORD
GREEN SALES CO.
D6TZ-2853-B .. Front Parking Brake Cable - 89 5/16" long / Obsolete
GREEN SALES CO.
