Derale Dual Speed Fan Wiring
gpeplau
Newbie
Hey all,
I just purchased a Derale Dual speed fan https://www.summitracing.com/parts/DER-16822
I purchased the fan because I read on the forum that some of y'all were using it. I am currently in the process of wiring it in using a dual temp sensor from an early 90's BMW and 2 relays(one for high setting and one for low). The wiring directions that come with the Derale unit are weak at best. It shows that the grey wire is the low speed and that the brown wire is the high speed. When testing the operations of the fan with my battery, I cannot tell any difference between the two speeds. However, when I put both of the brown and the grey wire to the positive terminal, the fan goes to a significantly higher speed. My question is this: when wiring the high speed relay, do I splice both the brown and the grey wire together? I am afraid that if I do not that the fan will stay at the low setting regardless of engine temp. Any advice from those run this fan is much appreciated.
Timmy390
Conway, AR
I think that's the fan I used only without the shroud.
Give this a try. Note I used the 95 stang ecm to trigger so your wiring will be slightly different. Also as I recall it will only trigger high speed if low speed is already triggered. Think that's in the instructions someplace.
Tim
I would presume the low speed switch stays connected even as the high temp switch comes on. Thus the same as going from 1 wire to the battery test to both wires on the battery at the same time test.
