hc37180
Been trying to diagnose some idling issues. Vehicle started idling about 3-400 higher than normal. Will at time go back to normal but when driving around it will constantly stay up around 1100rpm. I have read up that issues can be dirty Idle Air Control (IAC) and/or throttle body. I also read in a service manual that you can put a tester across the leads on the IAC and it should have like 7-13 ohms resistance. I tested it (reversing the connections to make sure I had all bases covered) and the ohmmeter pegged off the charts in the negative direction. Am I to assume that means the IAC is shot? Anyone ever replace this unit on their EFI?
Thx
Thx
