SeaninSt.Cloud
- Sep 21, 2007
- 130
I have a 302 mud truck with a power steering conversion-I think the steering gear is from an F-100. It is like 16" long. I have a stock pump-the round kind-it was used.
I had to change my crank pulley and water pump pulley to fix an overheating problem. So, I cut down a 3groove crank pulley (about 6 3/4 diameter) to a single groove and put a 2 groove pulley on the water pump (about 5" diameter). I have a belt connecting the water pump and crank, and the second wp groove to the ps pump. I backed it out of my driveway to let the engine run for 1/2 hour to test the cooling system, and when I went to pull it in I had no power steering. I had fluid in the pump and no leaks.
So, my question is-would changing the pulleys to smaller diameters burn out the pump? I understand the smaller diameters will increase the amount of revolutions, but is it enough to blow a pump? I do not want to replace the pump if this setup is wrong and have it happen again.
I think the pump was old and gave out.
Any ideas? Thanks
Any ideas? Thanks
