Differences between Painless and Centech besides the price
Miker
Okay, I searched for this but my search skills turned up nothing. So,,
Other than the several hundred dollar difference between the two, is there a good reason to pick one over the other? I know you can get the glove box and an extra 12 fuses with the painless but from an install to quality etc.???
It's such a difference in price,, if someone says "ya' get what ya' pay for", that's fine but what exactly would I be getting to justify the extra cabbage?
I'm not opposed to springing for the Painless, I just need some opinions as to if it is that much more "quality and improvements" over Centech to justify $300 or more difference.
maxwedge528
i just bought an unfinished 74 EB restoration that has a ron francis wiring harness....the installation is not quite completed. looking over the harness, fuse panel, and instructions i was surprised at how complete and how well thought out the package was. i dont know how price compares but you might want to check them out as well.
BUCKNBRONK
fresno
I put centech in a long time ago, great harness, lots of accessory wiring added in and every wire is stamped. Painless is overpriced, I was looking for a 3 relay set up from them they wanted $180 for maybe $30 worth of relays- I built one myself for $24 + tax.
Heus33
I had a centech on my last Bronco and it was very nice and the quality appeared to be great - had no problems with it.
I've never seen a Painless one to compare though.
Pcparas
I installed a painless wiring harness in my bronco last year and I was very impressed with the product. As far as I could tell it had everything a Bronco would need and more. The Harness it self seemed of high quality and everything you could possible need was provided. I haven't seen a Centech harness though, so like everyone else I can only tell you how impressed I was with painless.
zbronco
Houston
I went through the same process a couple months ago. I looked at all of the wiring harnesses on the market and ended up with a Kwik harness mainly based on price. I think most of the harnesses available today are more then you will ever need for a bronco. Now that I am about 80% into the harness install my feedback would be to download and read the instruction manual prior to any purchase and find out which provide better instructions. I found that painless has the best documentation and that is what I cross reference for my install. The instructions for the kwik harness leave a lot to your interpretation and omit a lot of details. I would also look for one that is specific to an EB. Yes you can make any of the harnesses work, it is just a matter of how much time you want to deal with it..
garberz
Bronco Influencer
Conejo Valley, Ca.
I just installed a Painless in my buddies Bronco. He bought the harness without switches. It comes with the correct terminals to reuse you existing switches. The Painless uses Ford color coded wire throughout most of the harness, I think the Centech uses GM color coding. Someone correct me if that's not the case. The Painless harness covers all years, so some of the circuits don't get used and harness routing will depend on what you you have. The glovebox is nice and having 9 accessory circuits is more than I needed, but it's there.
