Tedster100
Chairman of the Bored
- Aug 25, 2010
- 1,762
Last week I had the Bronco out and about a mile from the house it made a little bang in the rear end that sounded like the t-case popping out of gear. After that - no forward movement. I stopped and looked to see if I had a u-joint or drive shaft problem but everything was good. After getting back in and putting it in gear and releasing the clutch it just sat there. The trans was in gear and the drive shaft spinning, just no forward movement. I know because I left it idle in gear and got out to look, shaft spins but nothing to the wheels.
Back up 2 years..... I purchased front and rear built axles both with ARB lockers from a member who had them built at a local shop. I put them on last summer but never got around to the compressor, air lines and wiring for the ARB until about a month ago. With the pressure set to specs, I tried to operate both lockers in the garage with the Bronco on jack stands just so I could verify they worked properly. The front was good but the back just blew air into the axle and blew gear oil past the axle seals. Obviously there is a problem with the ARB and the axle vent. When I put the front axle in I noticed that the ball joints were old and a couple shot (the off road shop supposedly changed all of them but that's not what I found), this made me worry about the workmanship on the locker, diff, etc... I ran the rear end without the ARB operating for a few short trips, maybe 30 miles total and this is what happened.
I've pulled the rear diff and everything appears ok. Gears look fine, there's no visible issues with the diff. Putting my fingers inside I can feel the splines for the axles and the spiders are turning so I'm not sure if there is something internally wrong with the ARB or what. Is it possible that the ARB blew it's seal and engaged the locker beyond the normal operating range to the point where it seems like I have no ring gear to engage? I'm going to make up a bench mount tomorrow & then start checking into it more. Does anyone have any idea what could be wrong?
