NJB71
I almost completed the wiring of my tranny temp gauge, 2 questions....the sender wire, white...easy, the black ground easy, the 12v keyed(fuse box)easy....but there is a 4th wire that the directions ask to wire into the switched light source?-assuming the headlight switch, but when i looked under the very tight space of the dash I couldnt figure where the wire is placed? stumped.......
2nd question, the 12v keyed on wire into fuse supplys power, but the key isnt in the ignitiion and the temp gauge is on? what gives, I run several power sources into the fuse and dont understand the constant power source, thought it was only suppossed to come on when key was turned?
