Dipstick advice
67 Halfcab
As part of my 4r70w swap, I installed Hedman 88408 headers. I have the threaded engine oil dipstick pan and don't think I can make the stock dipstick tube work. Anyone running the 88408/88400 headers and Lokar or Milodon braided dipstick tubes have any advice which one works better? Thanks for your help.
nickgp
Im using the Milodon dipstick that snakes its way thru a set of JBL shorty headers. Works well. No big issues
AZ73
I'm using the Lokar with BC shorties on a Milodon oil pan which mimics a Ford Racing oil pan. dipstick hole is in same spot as factory Ford through the side of the pan spot. Works fine.
baddad457
You'd be amazed at what the stock dipstick tubes will fit. You can bend em slightly to tailor the fit to most headers. I would try it before buying anything else. I just put a set of Pace Setter shortys on my 1996 351W E150 van. the stock mile long dipstick tube worked fine with a little tweakin.
67 Halfcab
67 Halfcab
I already tried it. :cry: Between the tight fit of the headers and the WH extreme motor mounts, the tube kinked when I tried to get it to snake around in an "s" shape. :p Thanks for the tips so far, guys!! Anyone have any pics?
AZ73
Had to wait till I got back from Thanksgiving. Here you go: BC shorties, Milodon oil pan, Lokar dipstick.
67 Halfcab
67 Halfcab
AZ73, those BC headers have lots of room between the tubes compared to the Hedman 88400 series! They may have been the direction to go.
Airbur, are you using an aftermarket oil pan also, or is that a press in dipstick tube for the late model 5.0 block?
Thanks for the pictures, guys! :cool:
baddad457
Strange that the stock dipstick tube doesn't fit. I used the 89500 Hedmans with a roller 5.0 and the stock Fox Body dipstick tube in my 89 Ranger. The drivers side header in that set is the same as the 88400.
okie4570
NW OK
I've been giving advise to people about how to deal with "dip sticks" for years........but I don't think it applies here:p
67 Halfcab
67 Halfcab
This series of Hedmans are TIGHT!!!! :p Someone with more skill than me could probably get it to work, but I was/am running out of patience with a stupid dipstick!
baddad457
Oh, that's right, the dipstick's on the passenger side on the Bronco pan. Maybe plug it and use the driver's side ? I know the Fox dipstick will work on that side, should work with the Bronco pan too as they're both rear sump.
moosebob
I opted for the Milodon Flexible dipstick and routed it UNDER the headers and mounted it on the inner fenderwell. This made a much cleaner install in my opinion.
I tried running it between the header tubes and wound up almost burning it.
(it is rubber inside the wire mesh)
