Disc brake booster recommendation
malibubronco
I recently Install front disc brakes on my Bronco but I’m running the stock master cylinder at this time but want to go with the brake booster and would like some recommendations.thanks
bronconut73
All of the vendors on this page have the vacuum assist booster and bracket that simply bolt on.
It is apparently fine for up to 33 to 35 inch tires.
But the real hot ticket is hydroboost. These vendors have that option as well.
It costs more but it works much better.
sanndmann3
What Steve said. Hydroboost is the way to go. Got mine from an Astro van. Way better than vacume booster.
bronco italiano
You just can't go wrong with H-Boost. I would go with WH, as Jim doesn't fuss about shipping costs if a part is damaged or doesn't work out.
