RIDER68
ok i put the disc brakes on my 44 and went and put the explorer disc brakes on the rear put all new brake lines in it put the new proportioning valve in it for disc to disc and im running the bronco vaccum power brakes and i cant get any pedal, it works if you pump it up but there all the way at the floor then if u let it sit for a couple of seconds you go to push the pedal down there is no pressure and i had them bled at a shop and no air was seeming to come out but i just cant figure out why they arent working and none of the lines are leaking PLEAS HELP ME i need it driveable by tomorrow morning
