Disc Brake Swap ?'s, bleeding problems.
SDlivin
San Diego
Still trying to get this Dana 44 swap figured out. I did the GM disc brake swap as well.
Now I can't seem to get it Bled. Gone through bottles of brake fluid bleeding it and still no better results.
I only swapped out the front brakes, and lines from the top of the axle housing out to the calipers.
I've done plenty of brake jobs on my other vehicles in the past, never had a problem bleeding them out.
Any ideas? MC is for manual brakes, I believe as the port are facing towards the drivers door. Power booster is installed. Front small MC reservoir is running to the front brakes, large rear reservoir to the rear brakes. 'H' block on the frame.
Just keep bleeding and hope for the best?
SDlivin
SDlivin
San Diego
I didn't do it... I swear.... PO had it done, or did it....
It didn't have any problems with that when it was drum brakes all around. Worked great actually, only problem was getting a feel for the lock-up pressure.
I'll swap those lines, but I don't think that is the problem with bleeding the discs, as all that was there previously.
broncnaz
Discs take more volume than the drum brake wheel cylinders did. The smaller side of the resevior pushes less volume so the rear brakes are probably locking up before the front brakes get enough fluid to bleed.
Good answer laying blame on the PO. I can only do that with one of my broncos.
SDlivin
SDlivin
San Diego
Okay, I'll swap lines and bleed away.
As for laying blame.... The way things are going, soon enough I'll have no one else to blame, as there are very few things left on this rig that I haven't gone through, replaced, fixed etc.....
Did the swap include a proportioning valve? If so, you have to pull the little pin out (or sometimes push it in) to de-activate the delay valve.
If you don't have one of those, (I know you said you still had an H-block, but wasn't sure) are your bleeders facing up? Guessing they are, but had to ask.
With the GM calipers, did you clearance the knuckles so they're not hanging up and giving you a false signal?
Lunar-tic
Brentsville
I just did the disc swap on my Dana 30. Used a manual '68 model master cylinder w/o the residual pressure valve (no power booster). I bled probably two quarts or more through the entire system. I connected a rubber hose to the bleeder and ran it down into a clear bottle (allowed me to "recycle" the clean fluid) with about an inch of fluid in it. I bled each wheel until the air bubbles stopped appearing in the bottle. I repeated that process twice to make sure it was air free. I also bench bled the master cylinder. I am not using an H-block or a proportioning valve. The brakes work way better than the old drums but the pedal will go about half way to the floor before it firms up. I think it is because of the older master cylinder's lower volume. At first I thought it was air but, after bleeding again and reading up here I determined that it is just a charateristic of the manual '68 master cylinder. First chance I get I am going to upgrade to a later model power unit.
broncnaz
A 68 drum MC should be the same exact size as a disc brake MC. You might have a bad spot in the MC that leaks until you hit that spot which is why it doesnt firm up quicker. I've never heard of 68 MC's being any different from the other bronco MC's really other than 66/67 single reservoir MC the rest are all the same. the only differance in the 76/77 is the residual valve and port exit. bore size is still the same.
SDlivin
SDlivin
San Diego
I picked up the Disc brake set-up from a D30 a user was selling 6 mos ago or so, in anticipation of finding a D44 etc... I only grabbed the spindles out on the Disk Brake set-up, and the S/S braided brake lines.
So no, no proportioning valve. I'll take a pick, but I am pretty sure what's on the frame is just a simple H block.
I did clearance the knuckles and a lil' bit of the calipers to make sure they had rooom to slide. Figured that out after test fitting things.. :) and then reading some previous posts from here.
Calipers are almost exactly at parrellel to the/behind the axle tubes with the bleeders facing up.
Today if I can get around to it, gonna grab some more Dot 3 brake fluid, make sure I have a clean catch reservoir, swap the MC lines and bleed away. I'll try re-using the stuff that I catch, as I already went through quite a bit.
BTW, what is the purpose of the 'H' block? Just seems like it just acts as a pass through junction point. no real purpose?
I've read that when some do a disc swap, some need proportioning valves, others don't etc.... so, hoping I don't, but we'll see once I figure out this bleeding challenge.
thanks.
broncnaz
Other than a junction block and a place for the idiot light switch the H block serves no real purpose. A prop valve is only needed if your rear brakes lock up before the fronts. Most people dont use/need them as its usually not a issue.
Even if the calipers were sticking it shouldnt cause any issues with bleeding. It would cause poor braking.
SDlivin
SDlivin
San Diego
pics added
here's pics of the caliper, MC, and 'H' block, I am guessing that port on the back side of the H block is for a brake warning signal connection?
broncnaz
Yes that plastic part is the switch for the brake warning light on the dash. Oh one small issue is your brake line routing it could allow air to become trapped in the section of line that is higher than the MC. While it shouldnt be a issue once bled correctly its still a possiblity. I would route them under the MC.
x2. Probably makes it more prone to not only to be more sensitive to bleeding, but with all those joints and junctions, more prone to leaking some air in at some point. That usually shows up as a leak of course, but not always, and not right away.
And just to be sure, the line from the rear (larger) reservoir is now plumbed to the front brakes, correct?
And what about the pedal/booster/master rod setups? Did you verify that all the lengths are exactly as specified, so you don't have a squishy pedal that feels a lot like air in the system?
Lunar-tic
Brentsville
I removed the h-block when I did my conversion. Bought some junction fittings at the parts house to replace it, now the lines run from the M/C straight to the front and rear. No problems yet, rears haven't locked up before the front. I have read on here that some users have had better performance using a M/C with a larger bore/more volume with the disc conversion. Just a thought.
SDlivin
SDlivin
San Diego
Per others advice, figured I'd keep this thread going as it has most of the background...
so again.. brakes worked great before I went down this axle / disc brake swap.
Okay, so still having problems bleeding the brakes. Fluid coming out of all bleeders are clear of bubbles.
I am getting feedback pressure back on the pedal (which is good), but I am still getting bubbles coming out of the rear m/c reservoir, rear hole in the reservoir.
If I press the pedal down hard, release, then press down again and hold it, I get about a dozen bubbles coming up. (tried to capture in a pic) I did this process about 30x guessing maybe some air in the m/c, but it is still occuring, there can't be that much air in the m/c. My only guess is that maybe somewhere in the system, when I depress and let pedal back up it sucks air in at that point, then when I depress it again it is releasing that air into the m/c? But since it is occuring on only 1 pump of the pedal, the leak would have to be fairly close to the m/c?
I redid the lines from the MC (see pic) now I have the going under the m/c and I took out a section (less connections).
I made up new hard lines for the front, the hard lines that run along the axle.
Only a few things I haven't replaced at this point; the S/S braided banjo lines that attach to the calipers, the rubber mid line that is in the middle of the line that runs from the m/c to the H block (provides for flex, I guess)
Any ideas out there?
pcf_mark
Isolate the m/c by disconnecting the lines and putting on two short lines that dump into the reservoir. Pump the brakes until air stops coming from the ports in the bottom of the m/c. It should only take a few pumps. If it does then the you know the m/c is not leaking and has been properly bench bled. If it keep bubbling up air then the m/c piston to bore seal is drawing air in thtough the back where the pedal moves in and out.
Secondary question - if you pump the pedal a few times and plant your foot on it hard does it slowly go down? It may take a minute. If so you have a leak somewhere and/or bad m/c.
SDlivin
SDlivin
San Diego
QUOTE]
Like this?
Still getting air... I'll keep pumping it and see if it clears, but dozen times already and still getting air out of the rear reservoir, rear hole.
SDlivin
SDlivin
San Diego
Okay so pumped it up another dozen times or so, still getting air coming out of the rear reservoir with the lines ran back into the MC (previous pic).
Guess that tells me the MC is shot ?
Kind of interesting that this right when I do the disc swap, because brakes were working great before I tackled this. Pure coincidence or..?
73azbronco
is this an old or new MC? Might have gotten a piece of dirt in the cylinder bore? The sad part is you know its making bubbles, now you have bubbles in every brake line, ouch.
