Question, did you install new Mile Markers? I installed new Mile Markers (from JGB) and they didn't come with a spring like the stock version did and you aren't supposed to use the stock guts to my knowledge. So the rotors spun freely before caliper install and bleeding? As for the residual valve, the instructions say to insert a screw in the rear seat and pull the seat out. But, on my first try the screw broke off in the seat before the seat came out. Then I destroyed the seat trying to get the screw out so I ordered a new MC from Advance Auto and when I went to remove that one I discovered there wasn't a valve in it. So, shine a bright flash light through the seat hole and if you see brass/copper on the inside straight through the seat yours doesn't have a valve. If it is black, as in a black rubber valve, you'll have to pull it. Be careful and use a strong, quality screw and patience.
They weren't new Mile Marker hubs, they were on the D30 and on the Bronco when I purchase it a year or so ago. I also have a set of stock Locking hubs (from the D44) decided to keep/use the Mile Markers and I'll keep the Stock units as trail back-ups for me or others as needed.
Mile Markers as I installed them (as they were when I uninstalled them from the D30) seems to work fine, when locked both sides and yoke spins, when unlocked, nada.
When I installed the new MC I don't recall there being a rubber seat in the rear outlet port, only a brass flare.
Rotors spun freely this morning until I tapped the brakes and then they locked up. Appears brakes had overnight to release.
Well at this point, it appears I am going to have to take the MC off anyways to get to the actuator rod and to check the rear port again...
ugh... Off to the garage and another liter of brake fluid.
