B0neCrush3r
- Nov 8, 2018
- 61
77 Restomod, Coyote with 6r80, 17" wheels BFG KO2 35s
I injured my hand and can't work on the Bronco.
I took the Bronco in for an oil change and to have my tech check a squeak in the rear expecting to have it back in a couple days...that was 6 weeks ago. The squeak ended up being a bent rear axle.
Ordered a new set of Yukon 31 spline 9 inch axles (Chris at Complete Off-road), studs are not compatible with my older (10yrs) wildhorses disc conversion kit.
I ordered these:
https://www.wilwood.com/BrakeKits/BrakeKitsProdFront?itemno=140-13305-DR
https://www.wilwood.com/BrakeKits/BrakeKitsProdRear?itemno=140-13323-DR
E brake part # 3026 at WH4x4
Wilwood stated a manufacture date of 2/28 even after I offered a case of Bourbon to speed things up.
I'm open to some alternative suggestions or if you happen to have a spare kit laying around I would love to buy them off of you.
I also find it odd that there is a compatibility issue, is this common? I searched and couldn't find much info.
Thanks,
Nathan
I ordered these:
Thanks,
Nathan
