I bought, received and have installed my kit From Wildhorses but after reading a few online posts I think I might have messed up. *Can some please help me with the following?
1. *I installed the backing plate, but did not use the round ring because I did not know exactly where it went. *Do I need these? *The inner pad on the passenger side was hard to get in. *Could this have been due to the disc being just that little difference off?
2. *The pressed in spindle seal was not the same as what came off of my 73, so I removed it and used the rubber V type and on top of this did not see anything in the instructions that said to use the fiber washer so it was left out. *I see some posts now saying that it goes inside the spindle. *Do I need to tear it apart and put this fiber washer in?
3. *I had a hard time getting in inner hub bearing on the spindle so. Called Wildhorses. *I was told that the tolerance between the spindle and bearing is almost nothing and that I could put the bearing on the spindle and then slide on the hub. *Now I see a post hat tells me I should have installed an outer seal over the bearing. *Did I mess this up and should I take it apart and fix?
