- Oct 11, 2022
- 369
Thanks again!
So I can just disconnect the one stock black charge wire from the alternator and cap it off / move it out of the way?
Good point about the horn. Not sure I care very much about using it when power is diconnected, but worth considering.
That is a buss bar in the diagram; the switched side of the disconnect would have the black harness connection "(labeled "To vehicle harness/loads" in the diagram), which is not connected to the battery in any other way, so it should work as a disconnect I think. I'm okay with the starter being connected directly to the battery because the ignition switch won't work with the harness disconnected.
I'm also planning to replace the ammeter with the voltmeter from WH.
