Disconnecting Trans lines from radiator
Diehard
I'm stuck. How do you disconnect the transmision lines from the radiator?
73azbronco
with a flare nut wrench? I was going to say something witty like "with a tool?"
Try some penetrant oil on the threads for a few minutes, then use the flare nut wrecnh on the nut and another on the radiator housing. Slight tapping with a plastic hammer may help, heat as a last resort.
tejayandtina
Mine were pretty bad. Used flare nut wrenches. Still wasted the fittings pretty good. I also had adapters between the lines and radiator (one of which cracked). Be careful.
D
Diehard
Finally got them off with flare nut wrench....but eventually had to break out the visegrips and totally destroyed one of the fittings....but they are off. Thanks for all the input.
blubuckaroo
Grease Monkey
Ridgefield WA
Pull the battery out first. Ypu'll need lots of room. You need two wrenches. A flair nut wrench and a backup. Of course a pair of vise-grips will work in the place of the tubing wrench.
