While searching for the reason behind an inconsistent idle, I sprayed starting fluid around various vacuum hoses. As i sprayed near the distributor advance mechanism the truck made a tiny fwump sound. i wasnt able to replicate it consistently even after several attempts spraying directly at the distributor cap. not letting common sense deter me, I really layed on the starting fluid...as you can imagine the next fwump included a large ball of flame and then a small fire on the intake/carb base/dist. i beat the flames with some rags. those caught fire for a second but then fortunately everything that was on fire went out almost immediately. is there any way to check to see (not involving flammables) if my wires or cap are indeed "leaking" spark? Darwin will have to wait for another day.
