Hey Jdub0. Sorry to hear you're having a problem. It's a bit of a tall distributor, on an already taller engine. But not by that much in the distributor department I would not think.
Wondering if a stock Dura Spark would be any lower. Looks like it, but not sure. And then you're into all the wiring again rather than a simple one-and-done kind of a setup. Well more like two wires probably, but you get the point.
A body lift is the most common solution for either a too-tall distributor (even on a 302), or most 351 installs as well. A 1" body lift is the compromise for added lift without too much bumper/body gap.
Do you know exactly how much clearance you need? Unfortunately there's that hood cross-brace right there that gives us so much trouble when choosing distributors. But a 1" body lift is the usual solution.
Any resistance to a body lift? Some will cut the brace, but I'm not a big fan of that at all.
Good luck. Hopefully someone else has run into the same combination issue and had a nice clean cure.
