Distributor hold down bolt broken off
spap
Hey everyone, does anyone know how far you can drill down where the 302 distributor hold down bolt goes. The PO JB welded the hold down bolt in and I was adjusting the advance and it came off. So it was broken off in the intake manifold. I was thinking of putting grease on a drill bit to catch the filielings so I can drill out and retap the hole but I didn't want to hit a water jacket in the stock 77 intake.
Anyone have experience with this?
Any ideas?
NYLES
Dizzy hold down bolt doesnt go through intake. Goes into the top of the block.
spap
spap
Thanks so you think I have room to drill out the broken nolt
baddad457
A better solution would be to weld a 9/16 (3/8") nut over the broken bolt, filling the hole with weld, and just as it cools from orange to grey, unscrew the nut, the bolt will come out with the nut if done right. Easy to do with a MIG machine, works 99% of the time, the first time it's done. You won't even have to remove the distributor. If you try to drill it, chances are good you'll eff up the block's bolt hole.
NYLES
Works great as long as the bolts broken above the block. Think Id try a bolt/screw extractor first with alot of penatrating oil.
KyleQ
Try drilling it and using a SQUARE bolt remover (Snap-On) and if that fails weld a nut to it and let it cool before working it back and foreth.
NYLES
if you have just a lil bit of bolt sticking out weld a flat washer(inside the washer) to that then weld a nut to the flat washer....then take it out!
spap
spap
Thanks guys ya ita broken off below the block surface, I'll try an extractor see if that works and soak for a day. But if I have to drill it out how far can I go down.
Thank again
Highly discourage the extractor. They are very hard and brittle. If the bolt broke off due to rust or other damage then the extractor will not remove the bolt and the broken extractor will not be removble. You can't drill them. They like to expand the bolt in the hole (making it even tighter) just before they break.
Left hand drill bit, you can go in about an inch from what I remember. If the bolt will come out with an extractor, it will come out with a left hand drill bit.
spap
spap
Thanks BB good call on the left handed drill bit, sounds like it will work. Can't believe the PO just job welded and thought it would hold, wondering why my timming kept changing
DAKOTA7720
CASS COUNTY, MN
Anyone ever tried spark erosion?
Some acetone mixed with tranny oil applied and left overnight would go a long way IMHO. I still think an extractor bit should do the trick. Can someone explain the logic behind the left hand drill bit? Aren't they nearly as hard as the extractor tool? I did see some other posts where people took the anneal out of the broken extractor/bit with isolated heat to eventually drill it out. PITA
The LH bit drills out the core of the bolt. With luck the tension on the threads goes down. Then the drill bit catches a bite n the bolt and it just unscrews. Since the drill is spinning in reverse the rotation is that of removing the bolt, not tightening it as you drill. What you gain over just going to a straight extractor is a chance for the bolt to come out during the coring process. The extractor, when driven into the cored out bolt, expands the walls of the bolt, driving them tighter. I have NEVER seen an extractor work on a frozen bolt. Only chance I have ever seen one work was one that was overloaded and failed. Overloaded broken bolts are not stuck like a rust frozen bolt.
NYLES
bb IM GONNA GIVE HAND THIS ONE........forgot but backward bits!
pick up a cleaner tap while ya there!!!!!!!!!
baddad457
Yea, then he'll have the broken extractor to weld the nut too. ;D Long, long ago I used to try that method, and 99% of the time the extractor broke off in the hole, or the hole ended up off center. The weld method will work even when the bolt is below the level of the top of the hole. The weld attaches to the bolt, the intense heat loosens the threads to where it's usually hand tight coming out.
