Silverhorse
DIY Beadlock Wheel Kit SOLD
These bead locks are the original design that sits just inside the wheel lip. The reason for this is to prevent the tires from being damaged when there installed and removed. Unlike other designs where the bead lock is flush to the outside lip, tires can be damaged and are difficult to install and remove. Another benefit of this design is that the outer lip is almost impossible to dent.
bead locks feature 32 bolt holes 3/8" diameter.
Bolts, washers, and nuts included
