DIY extended radius arms
77bronconut
Lebanon, TN.
I have been browsing around at different radius arm extensions and even hinged radius arms. Any advice or recommendations. I am running 4.5 deaver coils and want to extend them 10"-12". Show me any ideas you may have or give advice. I am proficient welder and would like to fabricate as much as I can myself. ??????????? thanks
bronko69er
EB Addict
Renton, WA
I built mine 12" longer for about $100 in material, moved the stock mounts back on the frame and used stock urethane bushings. This setup will not bind before my springs run out of travel
I bought rectangular tubing to fit over the outside of the arms, scaffed the end to have a nice taper and be able to weld in a 1" corse thread 10" long bolt, and capped the taper with flat bar. (cliff notes version) I can go into more detail if interested.
http://classicbroncos.com/photos/showphoto.php/photo/12349/cat/6262
thumping
Jacksboro Tn
Check out our radius arm extensions at www.stonecrushersteering.com They are on the other products page. We build both styles of extensions...heim and stud. If there is enough interest (5 sets or more) we could do a mass buy with special prices for Classics.
Thanks, Anthony.
ET
Dallas, TX
Thumping. Do you just weld up the extension to the stock ends? Is that strong enough?
Eugene
DonsBolt
Chestnut Hill, Mass
Anthony
I might be interested in a set of the extensions, but
can you make a shorter set with a heim, or better yet a Johnny Joint?
I would like to extend my ams about 6 inches
thumping
Jacksboro Tn
Eugene
They install by threading onto the stock radius arm threads and then they need to be welded to the butt end of the stock arms. We decided that we really did not like just slipping an extension on and welding and designed them to thread on to gain some extra strength that stock stud provides.
Anthony
thumping
Jacksboro Tn
Anthony
Yes, Don we can make them to the length you need. We don't carry the Johnny joints but I can thread them and you can use any other joint you like. I'll just knock the price of the heims off if you would rather use something else. Sound fair?
The Classic’s price special will be $102 plus shipping...right at a 25% discount. If we can get at least 5 committed sales I'll (hopefully with Jon's help) run the mass buy starting Oct the 1st through the month. That sound okay?
Anthony
357Bronco
New Hampsha
I'd be in for 2 sets, one with rod ends, one with mounting studs. Any chance of a mass buy on the steering set ups in next several months?
thumping
Jacksboro Tn
We're getting close to 5 sets. I'm not sure how to set a mass buy up through Classic's but maybe Jon will jump in here soon and we can get everything set up to roll in Oct.
As for a steering mass buy...maybe after the first of the year...we'll see if there is enough interest.
Thanks, Anthony.
Mark
Bronco Klutz
NW Indiana
Anthony
This thread has my attention!
Anthony, would a nonstandard extension length be included in the mass buy price?
Don are you firm on that 6 inches? That's what I'm considering also - any thoughts on 8 inches? What is your opinion Anthony? Anyone?
I'd go for the stud end, so I can still use either a rubber bushing or poly urethane. I think the heim's don't help with ride comfort.
Tito
CB Fire Starter
Bakersfield, CA
Anthony
Do you suggest plating them as well? What kind of abuse have you tested them through so far? Also the heim end, is that also going to be the $102? What size heim? And do you sell a bracket to use the heims too?
77bronconut
Lebanon, TN.
OK, somebody school me on heim joints. I thought a heim joint would have some side to side play, would that affect the steering or stability. I had in mind using the stud end with rubber radius arm bushings.
gearida
Newburgh, IN
The Heim ends do have spacers in most applications or they could use a tapered shim to hold the joint in the proper location.
77bronconut
Lebanon, TN.
It seems the heim would have lots more flex than the stud/buhing design,are there any reasons not to go this way? Someone mentioned ride comfort how would it affect that? I basically want to maximize flex with the existing springs (4.5 deavers) and want to stay w radius arms. The extensions look good from stonecrusher, but are they strong enough by just welding around the extension and not reinforcing with plate or tubing tying the old to the new? Sorry for so many ? I just want to do it once....and right. bronko69er looks like he's got it figured out, but would his design with heims be better?
bronko69er
EB Addict
Renton, WA
Heims do transfer more shock and vibration into the frame allowing you to "feel" the road more.
If you are worrled about flex I can assure you that the setup I'm running doesn't limit flex at all. I verified this when installing it. The springs run out of travel long before the urethane bushings bind up.
One potenetal downfall of my setup: Since there is no bend in the ams you will actually lose a little bit of turning radius with stock width axles since the tires will hit the arms. It isn't an issue for me since I run the F150 axles.
I can't take credit for the design, I got it from bmc69.
http://www.classicbroncos.com/forums/showthread.php?t=90545
http://www.classicbroncos.com/forums/showthread.php?t=90656
thumping
Jacksboro Tn
Okay, let me see if I can answer all the questions.
Yes, we will do custom lengths in the mass by…a little longer or shorted with in reason.
Yes, the buy will be for either style, heim or stud.
The stud version, while they may not have quite as much flex as the heims they do have a better ride while on the street. They also allow you to use your stock mounts after they have been relocated.
No, we do not supply frame mounts for the heim version. Most people already have an idea of the type of mount they want to fab for their application. I have built some mounts and will gladly explain what I have done. Basically I used two 4x4x ¼” plate for the inside of the frame. Ran a 1-1/4 with ¼” wall square tubing between the plates. Used four pieces of 2x2x ¼” angle to sandwich the heims between. Simple, effective and cheap.
We use FK bearing ¾” heims on the extensions.
As for plating, we have customers that have plated over the radius arm and extension to form a tapered box and others that have just threaded them on and welded them up. Both have had great success. We are working on making prefabed plates that will box the entire arm with the extension as an option and should have them ready soon. If it falls through I will post PDF drawings with dimensions on how to box the arms on our site. The plates will work on all of our extensions…past, present and future.
As for the heim letting the front axle wonder…the track bar stabilizes the front axle’s side to side motion. Using the extensions with heims is no different than using Cage or Duff long arms.
I think I got all of them but if I missed one, let me know. ;)
Thanks, Anthony.
