Okay, let me see if I can answer all the questions.
Yes, we will do custom lengths in the mass by…a little longer or shorted with in reason.
Yes, the buy will be for either style, heim or stud.
The stud version, while they may not have quite as much flex as the heims they do have a better ride while on the street. They also allow you to use your stock mounts after they have been relocated.
No, we do not supply frame mounts for the heim version. Most people already have an idea of the type of mount they want to fab for their application. I have built some mounts and will gladly explain what I have done. Basically I used two 4x4x ¼” plate for the inside of the frame. Ran a 1-1/4 with ¼” wall square tubing between the plates. Used four pieces of 2x2x ¼” angle to sandwich the heims between. Simple, effective and cheap.
We use FK bearing ¾” heims on the extensions.
As for plating, we have customers that have plated over the radius arm and extension to form a tapered box and others that have just threaded them on and welded them up. Both have had great success. We are working on making prefabed plates that will box the entire arm with the extension as an option and should have them ready soon. If it falls through I will post PDF drawings with dimensions on how to box the arms on our site. The plates will work on all of our extensions…past, present and future.
As for the heim letting the front axle wonder…the track bar stabilizes the front axle’s side to side motion. Using the extensions with heims is no different than using Cage or Duff long arms.
I think I got all of them but if I missed one, let me know.
Thanks, Anthony.
