Do I even need a new trans?
bsteab0yz
Getting new engine (blueprint 306) in a 74 bronco. Has slightly larger than stock tires. Bronco will be used for driving around town, max speed 65-70 mph TOPS. Longest trip will be 45 mins or so. Decent amount of stop and go around city.
The current stock trans works fine, shifts smoothly.
Question is, if trans is working fine, but money is not too much of an issue… with the new engine, should I be looking at a 4 speed or just roll with the 3 speed? Didn’t know if it would be causing too much stress over time on engine, or just using more gas.
bigmuddy
Marthasville Missouri
The 302 engines were made to rev high. All that noise is just that: Noise. Its irritating but isn't causing any damage over the long haul. I think most of us have gotten use to the low rev when running overdrive trannies and vehicles with lots of noise abatement.
MPG? well maybe if you had another gear it would help to a small degree but going from a 3 spd to a 4spd doesn't net you much. Keep in mind your driving a brick..
As was mentioned the AX-15 like other overdrive trannies do help with lowering the RPM but can you recover that in savings in MPG? Well lets just say mileage may vary, based on current gearing, tire size, driving style, top speed when running down the highway etc.
For you, the 3-speed is probably fine. Slightly larger than stock tires already gets you a little overdrive effect going on. Adding more to the transmission generally improve anything. If you are running the standard 3.50 gears I don't see an overdrive transmission being benificial. But the 4.11 gears, that could like an overdrive if the tires are still small enough.
The typical transmission upgrade is to gain a bigger spread in ratios. You could do a 4-speed swap and actually have a narrower spread in ratios. But typically it is a wider spread. But it also has to be a usable spread. If top gear is geared too tall and isn't usable, well it isn't usable.
bmbm
Without knowing how much taller slightly larger tires are or if you have 3.50 gears, probably 3.50 if your Bronco was originally v8, you may appreciate the increased drivability of say a NV3550 or similar. It has a lower first gear than the stock trans which has been beneficial for me in situations off-road where before when using transfer case low-range was just barely needed and often just for a brief bad stretch and for the minimal amount of time I am in stop and go traffic. Also just nicer to drive overall with the right gear for any speed because in addition to the slightly lower first, 1-4 are somewhat like a close ratio 4 speed, which is handy for me in mountainous northern NV with constant elevation changes for on-road use. Then for even short drives on the freeway/highway the od gear provides a nicer experience with less racket.
