Do they handle that bad?
matts460
Castor is basically the mounting angle of the axle. Positive Castor helps high speed stability by tilting the top of axle rearward but also makes steering ability more difficult because the steering has increased abilty to self center. Negitive caster has the opposet effect. Also setting the toe IN would help steering control better at speed aswell since the wheels try to pull apart from eachother at higher speed. If toe OUT to much would make vehical very darty left or right. Broncos have a straight axle so camber is a non issue since the tires have full contact in a curve. The wider the tires are, the more the vehical will tramtrack or wander uneven road surfaces and have increased steering effort but will have more contact with road and handle better. Lots of trade offs considering how you have your Broncos setup. The later broncos went with the Y steering to help with bump steer. When suspensions compressed the links have more pivot thats also a bad part about track rods/ panhard rods that locat an axle.. they typicaly need to be as level with axle as possible cuz as they move extreme up and down the rod will push the axle to one side or other. just a few thing to think about. LOL
