Do you guys like rocker panel covers?
hollowch
Midland, TX
I've just noticed that my (apparently crappy) bondo job on my drivers side rocker panel is now cracking and it's looking like an eyesore because the rest of the paint on the car looks great.
I'm hoping that there are some decent (Not cheap) looking rocker panel covers out there that could help me solve this problem without having to get it repainted and rebondoed.... Thanks!
pictures or links appreciated!
phred
Earth
Personlly I do not like them because often they are hiding bad bodywork or rust. If your rockers are solid and only dented I'd knock the bondo out and prime/seal the metal and then install rockskis from BCB or Duffs. If the rockers are rusty I'f replace them. Just my opinion.
regshawn
Portland
I liked mine so much I cut the entire rockers off, bobbed the fenders and turned it all in to the scrap guy to send to China! ;) :)
73stallion
Eugene, OR
admittedly, mine ARE covering a little rust under the rocker, but they also saved me once when i came down hard on a rock i was going over. i've considered removing my rock skis, cutting off my rockers, and welding some square tubing on.
Heus33
I dont like the diamond plate covers. Some of the SS ones look okay if it flows with your paint scheme.
Personally I like the rocker wrappers from The Bronco Ranch. You can see them in this video
[youtube]njlFsDiG0xw[/youtube]
JSBX
I agree with Half Cab. I have them on mine and they are covering some rust but I like the look. I also have diamond plate in the bed for quarter panel covers. Good thing we all don't have the same taste. It would not be good if all our Broncos looked the same. See if you can find a picture of one the same color of your Bronco that has them and see what you think.
hollowch
hollowch
Midland, TX
I really like the look of these IF they were able to function as steps... Correct me if I'm wrong but I don't think they are supposed to be stepped off
asinor
Tulsa, OK
Someone here made a set that you can use as steps. I'll see if I can find the post.
Greg_B
Cohutta, GA
If you dont like the look of your rockers then why not cover it up with rocker covers until you are ready to repaint in the future? Sounds like a good way to make your Bronco look better without a lot of work.
I like the thicker smooth covers but if diamond plate goes with your scheme then they are fine as well.
I say go for it...
Greg
half cab
Guru Bronco
Mars was suppose to be making some awhile back....I don't know what happened..
Broncitis
MEB Founder
I know some of you like it, but diamond plate ANYWHERE on Bronco makes me cringe! ?:?
IMO it just looks dated and tacky in most cases.
I totally do not understand the fascination with the stuff? Entire garages full of cabinets made from it, light switch covers, wainscoting, workbench tops, WTF?%)
There are only a few places I like it...On some places I step ("tread"), and on firetrucks.
...Oh, and on the stone guard on the front of race car trailers it is ok since it is functional to hide stone chips and abrasion that would show up on polished or mill finished sheet.
The formed smooth steel rocker guards look good, as do the ones with tube nerf bars welded in like Duff's.
My favorite however is the Hanson rocker guards they used to make. American Bronco or someone makes similar ones, but they need cut to length and capped.
Here are some I installed on a rig I built for Mtfit several years ago. These were the American Bronco ones and I cut them to just the rocker length and capped them. You can also leave them longer and trim your flares to flow into them.
Its a bit hard to see in these pics, but I did not have any real close ups when I installed them. They have a nice shape and also function as a step and nerf.
miikee73
Shadetree Guru
Aloha
I have a Duffs set on mine and I use them for steps every time I get in.Also for loading the roof rack.I just put strips of grip t
ape on the bars.
xcntrk
NOVA
Personally I prefer the rocker protector and rock slider approach instead of covering up the original body. Properly secured to the frame and you should never see the rocker protection and body to ever make contact.
Here's the ones I'm whipping up. Mounts under the rocker panel and secures to the frame (also serves as a step).
Heus33
These are made to be stepped on - stepped, jumped, bang your shin, have at it! :p
Broncitis
MEB Founder
Dated.....LOL I feel dated and tacky myself.....My Bronco is for sure dated...:p it's 36 and counting...I use to like you....;);D
LOL.
I like a cleaner, more styled look that diamond plate just does not do for me.
Like I said, I guess I just do not get the whole attraction to it?
Next time you consider diamond plate, ask yourself WWCFD? (what would Chip Foose do) ;D
hollowch
hollowch
Midland, TX
I really like the looks of these things... Sooo you're saying it's safe to step on those even though they aren't tied into the frame?
Btw, your shop looks like a sex dungeon. Lol =]
Rustytruck
nothing is as pretty as nice virgin rockers on a trail rig but in that context nothing is as ugly as smashed in rockers. My view if you desire to add rocker covers then might as well do it right and get them heavy enough to actually add protection. If your rig is really pretty, rocker protection with a step can save you from alot of parking lot door dings.
pretty, smashed, rusted and even diamond plated I like all Broncos. Its yours do it your way.
Broncitis
MEB Founder
That is my buddies paint room at his shop where I painted them, but I will tell him.;D
Yes, I can not recall how many fasteners I used, but they were secured with 5/16 stainless steel button head screws into riv-nuts I installed into the rockers.
I've seen these on other rigs get laid up into rocks and trees with no damage to the body. Rockers are very strong overall and can support a lot, they just need the load spread over them with something heavier that will not dent.
