Dodged a bullet with my ignition
anoblefox
The ignition switch has been acting a bit hinky lately, it moves from position to position too easily, and actually shut off once while running in park when I very gently bumped the key fob. I did not really question it at the time, it seemed kinda freak. Well, I ordered a new one since this one has been installed for about 8 years now. I put off the install for about a week and today I decided to change it out. I removed the key part, then attempted to remove the center nut that holds the switch in place and the working half of the switch fell on the floor! The connector was still on the back part of the switch. We have been taking the dogs on a somewhat remote trail that goes about 7 miles through several very large ranches and there is no cell coverage there. So glad it did not fail while back there or even worse while on the highway. The original switch lasted 37 years and was actually still functional; I hope this one lasts as long as I do!
Saw that happen once before and another lucky break.
We had a gathering over at one of our local builds, later one guy was getting ready to drive back to Monterey and when he put the key in and turned it not much happened. A little flicker and nada.
Feeling around in the dark it turned out the switch assembly fell out the bottom of the dash! Just sitting there hanging on the wires staring up at him and laughing.
The lucky part turned out that there were several ignition switches sitting on the shelf in the shop. 10 minutes later he was back in business.
That was his original switch too, so made it about the same as yours. Maybe closer to 40 years. Hopefully the replacement can last half that long!
Ovalis
Los Angeles
That's why it's good idea to keep a piece of wire with some alligator clips and a screwdriver or something (to get power to the S lug on the solenoid) in your glovebox. Connect the wire from your battery (or the solenoid) over to the ignition coil, use the screwdriver to get it started and you're going. That's what i had to do on my rebuild to move it around before I had the wiring harness installed. Sure it might send a full 12 volts to the coil and mess it up, but small price to pay than be stuck out in the boonies.
Just always make sure before you go through that routine to program your mind to be certain that the transmission is either in neutral or park in the parking brake is on!
anoblefox
anoblefox
Yeah and don't ever bypass your neutral safety switch if it fails, unless it is done just to get you home!
