Dome light on cage
Brent13
Colorado Springs
Anyone figured out a dome light or lights mounted a roll cage? I am going to start looking into this, but figured one of the talented Bronco owners on this forum has tackled this project already. I am really needing some interior lights. I don't ever plan on using my hardtop, so cage-mount seems plausible.
Thank You,
Brent
bigdaddyof4
Vincennes, IN
I used these LED light strips for a dome light and drilled a small hole to fish the wire through for a clean look. I also put one in my center console.
70_Steve
Old Guy
I used this...
Dome Light
It works really well and I have yet to kill the AA battery. I will likely add a couple to my crawler as well.
And another thumbs up from me, cheap, easy, removable, effective, etc.
http://www.tomsbroncoparts.com/product/led-roll-bar-light-new-66-77-ford-bronco
I use the same one but got it from Wild Horses.
http://www.wildhorses4x4.com/product/RollBarMountDomeLight
B
Brent13
Colorado Springs
Nice, liking the look of the Rigid. But the simplicity of the battery powered light looks nice. Think I am leaning towards two of the Rigids, and wiring to the headlamp switch. How difficult a job would this be? My cage is already padded and taped, suppose I could cut the tape and run wires under the pad, and then re-tape, that would be clean. Would I be better off running to headlamp switch or a separate switch? My wiring skills need work. I always get it to work, but never a textbook install.
Thank You
edones06
I also used led strip lights one on my cage one under the dash and one onder the lip of the body on the inside of the quarters shining in. Thay are super bright and faily cheap from surplus center. I have mine wired to a seperat switch. But my hole truck is rewired and no longer has any factory switches in it
landshark99
Montrose, Colorado
broncoman1972
I am planning to make one similar to what Dusty linked to. I have 20 of the cheapo led lights from China for rock lights and plan to use one for dome and one or two for cargo lights.
377
The Bluegrass State
I have three of the Rigid Lights and I can only echo what the others said. They mount nicely,simple wiring and are really clear.
The ones linked to in the beginning of the thread can either be strapped to the bar, or the magnet that's buried between the strapping and the light body can be utilized as well.
We turned one on a couple of years ago to see how long it would last. Took almost 7 days to get it to a point that it was considered dead. The lights were still lit, so there was still some life left in it. Just not enough to read by or change a tire.
B
Brent13
Colorado Springs
Finally got this done. Went with the Rampage battery powered lights. Got two mounted to the roll bar. Think I am going to like these. Will probably add a third to the bar at the back (family cage). Thank you for all the suggestions.
Brent
englewoodcowboy
Lick Creek Restorations
I am going to try a different route taken from my boat lighting. These will be placed in the center hoop and rear hoop. I will have to do some testing, I bought 6 to make sure I could get enough light etc, may only need 2 but wont now till I rig it up and test it first.
