unimogger
My bronco is hardly ready for the efi/5.0 swap, but at $350 I couldn't pass this up. Decided to pull the engine and trans together, land them on a pallet, and stash till the time is right. I'm not a stranger to modern vehicles, tight engine bays, etc. I've done some unorthodox engine and trans swaps, and can generally make stuff fit where it isn't supposed to. My arms are skinny, and I've got 40+ years of doing this sort of thing, so, no big deal right?
I'll say that pulling this was the single worst job I've had to do for a good long time. And thats with me hacking the thing apart. Every conceivable socket and wrench out, with extensions on extensions, and swivels on that.
Engine mount bolts to the block are not accessible on the driver side or passenger side. At least three of the four aren't. The bottom frame mount bolts are blocked by the axle hanger brackets. The top bolts are accessible, sort of. You have to remove the passenger side mount for the starter to clear, or pull the starter. The exhaust won't fit past the drivers side mount, and you can't reach bolts to get the pipe off the manifold with anything. I used a half dozen grinder wheels and some sawzall blades. The trans wont drop enough for the fan to clear the radiator support, unless you jack the explorer up. I had had enough and just sawzalled the front off.
Good grief man. Thankfully I had carefully removed the harness and ECU while I still had some patience.
I'm half belly-aching, and half warning anyone else what to expect.
Just a bear of a job
