So, I'm working on a '69 Sport that had a lot of body rust. Using TBP (for reference). On the driver's side I'm trying to replace the front fender 1918, inner front fender 1935, front inner fender apron 1900, inner kick panel 1945, front door post ("A" pillar), and lastly the rocker panel. Somewhere, I found a diagram showing the measurements from various points between the front pillar and the rear pillar. I set it up as close as I could to the demensions stated for 4 different year vehicles. All pretty close to one another. In trying to put the door on there is a serious difference in the rear latch parts, something like 3/4" to 1". Even with a !/4" of shims on the bottom hinge I didn't get it to line up. I've had to remove the front pillar several times and even ended up purchasing another one was to look the first one was starting to look like swiss cheese. I must have measured the replacement pillar 50 times to make sure it was still correct according to the printed diagram. It was held in place with vise grips (more than a dozen of them. Experience has taught me that the weight of the door will over ride the power of the dozen grips. So, I had to weld the pillar in place AGAIN only to have the same out come. I'm able to mount the pillar to the door and mock it up in place and them weld the pillar to the apron.
All the body mounts are new and torqued to 40 pound specs.
Advise here please would sure be appreciated.
