Door lock drawing
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
Here you go.
  • 77 Latch.pdf
  • 77 Windo.pdf
DonH
DonH
WA State 30 miles from the beach
Thanks Oldtimer
That drawing does not show the push button door latch very clearly and the rod 22152 seems to be made different than the one pictured and that seems to be my problem.
It looks like I have done something wrong. Thanks for the help.
I have to take apart the other door maybe that will help.
Don
Oldtimer
Sunnyvale, CA
If you are installing new outer handles, the push button does not work correctly (at all) on many of them.
PaveBronco
Had the same problem with some new ones, even swapped out some of the parts for the originals, no change. lived with it for a few years. Just got some satin black ones from Wild Horses, expecting the same issue. They work great, very well built, the push pin on the inside doesn't wobble around so the button 'feel' feels like quality. Now if I can only get the door to shut properly.
