Bronco Paul
- Nov 18, 2006
- 266
Ok...so I'm replacing the door post, inner kick panel, inner rocker panel, outer rocker panel, and then the floor board. I've jacked up the dash to get everything to match up the measurements...
I've lined everything up according to the chart...I used the 71 sport measurements.
Made sure that the inner kick panel lined up square to the cowl.
But there little things that aren't lining up like the inner fender to the inner kick panel at the top.
...the door post doesn't match up flush with the inner kick panel and there's a gap between them at the edge so they don't sit flush to oneanother.
...the outer rocker panel dosen't mount up flush with the quarter panel at the bottom.
...and the roof doesn't sit on the quarter panels anymore.
Now if I let down the jack the measurements are off on the distance from the top screw hole on the door post and the floor and the inner kick panel isn't square to the cowl...but most of the problems go away. Has anyone else had this problem? Any ideas on how to fix this???
