kscarter
I'm in need of some help to correct the gap between the door window frame and the windshield frame. I have replaced the rockers, door post and kick panel and have them temporarily screwed into place while I make sure the door hangs correctly. All the measurements are within a 1/16" of an inch from the original door post and the gap between the rear quarter panel and door looks good and even all the way up and down. The top of the door is in line with the top of the rear quarter and the gap along the rocker looks good. I was very happy with it until I saw the gap between the door window frame and the windshield frame. I would expect a small gap since all the weatherstipping has been removed but it's about a 1/2" at the bottom and more than an inch at the top. If I raise the door, I don't see how I will be able to keep everything else lined up. The windshield is all the way against the stops an I don’t think bolting it down will make it pull down any more that it is. I can pull on it and even the gap out but it takes quite a bit to get it there. I’m hoping someone else has all ready been there, done that, and has the t-shirt. Any help / advise is greatly appreciated.
