ft bronc
Before I go back to the driveline shop that balanced my rear driveshaft, I could use some opinions. I've got a completely stock '73, 302, C4, factory posi front & rear. Tranny died two years ago & I finally got it back on the road. Here's the work I did while it was down:
Front:
Had the tranny rebuilt.
Replaced the T/C mounts w/ new urethane mounts.
New u-joints on the front axles & new ball joints.
New brakes w/ new drums.
Rear:
Rebuilt the rear drive shaft. All new spicer joints & new CV collar. Did not change slip joint as it seems OK.
Had the diff rebuilt - all stock.
New axle bearings.
Got it back on the road, and it rides and drives awesome, except for a high speed harmonic vibration that seems to come from the rear driveshaft. Pulled the shaft and had it balanced. No improvement, maybe a bit worse. Got the tires balanced today & rotated them. No change at all in the vibration - still feels like it's coming from the rear shaft.
The driveshaft had a lot of weights on it stock, and the shop added more weights to it on both ends. On one end, 180 degrees opposite the old weights, and on the other about 150 degrees opposite. They also added weight to the slip joint, which I had never seen done before.
The only other possibility I can think of beside the driveshaft is that one or more of the tires flat-spotted from sitting so long, but I did move it a few times while it was down. Tires are Michelin LTX's, with maybe 7,000 miles on them.
Any ideas? The vibration was not there when the tranny died two years ago.:-[
Front:
Rear:
New axle bearings.
