blue bronc
Here is the deal.
I had my transmission rebuilt in 12/08. Have not had any trouble with it.
About three weeks ago I was on my way to the auto store and started have this loud nock under the bronco in the transmission area. It was obvious that something was very wrong. Luckily I was only a couple of miles away form my transmission guy so I limped it to his shop and left it for him to check out. He called me right away and said that the rear drive shaft was shot and had a lot of play in it and that is what was rotating and hitting the floor. So I took the shaft to a recommended shop and they rebuilt the entire thing. All new u joints CV kit. I installed the shaft and went on my way. I have noticed in the last two weeks that there is a nock that can be heard from the inside of the cab. Not a bad nock but it can be heard. It will nock when under load or between 1500 and 1700 rpms.
Yesterday I took it to the transmission guy and we checked it out and ruled out the transmission.
The nock has to be the drive shaft.
My question is if I take the shaft out and have the shop check it out and it is balanced and good. What am I left with option wise?
Can you install the shaft incorrectly?
I know that you cannot tighten the ubolts too tight I made sure not to torque them down.
For background: 77 bronco with 5.5 lift and 33/12.50 stock 302 with auto C4 and Dana 20 I understand that the drive line angle might be a little steep but I did not have this problem with the last shaft. Till it went out.
Any ideas would help.
Thanks Mark
Thanks Mark
