Drivers floor pan replacement advice needed
Redbark
Let me preface this by saying I'm a complete noob as far as metal work goes.
I'm replacing the drivers floor pan in my '68 Bronco. I'm part way through removing the rusty pieces and I'm wondering what is the best way to proceed. So far I've removed the horizontal part of the floor board leaving a 1" strip along the inner rocker to attach the new floor pan to. This 1" strip is a bit pitted and has surface rust which could be ground clean. I still have to cut out the top part of the floor pan. and clean up the other margins as well.
The replacement floor pan has a 1" vertical flange on the left side that could be welded directly to the inner rocker panel and kick panel if I remove the 1" strip of old floor pan material flush to the inner rocker panel and kick panel.
What is the best way to proceed? should I Trim the floor pan to remove the vertical flange and weld it to the 1" strip of original floor or weld the vertical flange on the new floor pan directly to the inner rocker and kickpanel?
I'm inclined to remove all of the old floor and weld the new floor pan directly to the inner rocker and kick panel using vertical flange on the new floor pan.
All comments appreciated. Thanks.
cldonley
Robinson, TX
I removed the 1" strip you left behind. Using self tapping screws through the one inch flange, I installed the new floors and then removed the screws one at a time and welded the pieces in place throught the holes made by the screws. This is kind of a standard practice among the folks on the CB. There is at least one member who did this and made a Youtube video you can check out. Just do a little search in the tech section and you should find it.
For what it's worth, I did floor pans, front seat platform, trans tunnel inner and outer rockers and the driver's side door post and striker post and the doors went back on and fit great.
R
Redbark
Thanks for the response. Did you weld the flange from underneath or up above along the upper outside edge of the rocker?
kip60
It's probably easier to do from the underneath side (as long as the spatter doesn't catch your shirt on fire!). Ask me how I know! You can also punch/drill small (3/16-1/4") holes through the flange to get good contact also. I used a combination of self drilling screws and holes for mine.
cldonley
Robinson, TX
My replacement pans had the flange pointing up, so I welded from above. I imagine you'll need to do yours from below.
If you haven't already figured it out from starting to remove the top panel, save the cross braces if you can!
In other words, if they're not rusted out, try to leave them in without cutting them out. It's not a requirement for a clean install, but it sure helps when you're laying in the new piece.
When I did mine I went a different route. I "glued-n-screwed" mine in, instead of welding. Not as factory of course, but super strong and sealed and worked out well. Perfect method for someone not as comfortable with welding sheet metal.
I laid down a big bead of silicone sealer from a caulk gun, put the panel in place, drilled a few holes and used a few sheet metal screws initially to hold it in position. Then went around pop-riveting the thing to death.
Worked great!
Most people weld them in of course, but that's at least an alternative for you.
R
Redbark
Thanks for all the advice!
I managed to save the cross brace. It's a bit scarred but I can clean that up. I think I'll POR-15 it before I cover it up again. I'll apply weld through primer on the mating surfaces of course.
The glue-n-screw is a neat idea but I have a new welder toy that I have to learn how to use and a shirt to catch on fire;D.
bronconut73
Worked great!
I did this exact same thing 30 years ago Paul.
Still perfect....Well as perfect as siliconed and riveted floor pans can be, lol...I did remove the old rusted floor pans first....I have heard of some that did not...
I was not a proficient sheet metal welder at 17 so I did this glue, screw, and rivet thing....And while I "will" weld in some nice pans one day, (welding skills have improved immensely) these glued/screwed/riveted pans are still working so well it's hard to presently justify the cost and time...
cldonley
Robinson, TX
Glue and screw is a great way to go. But I talked my girls into getting me a new wire feed welder from Harbor Freight, so I just had to weld it! Surprizingly good little welder too!
Did have to grind off a few booger welds though. Thankfully, Herculiner covers a multitude of sins!
migs
I've used those same replacement pans a few time with good results after trimming them to fit my needs.
In your picture that strip (which is part of the inner rocker) looks pretty good to me. If so I would just drill out the spot welds to finish removal of what is left of the original floor under it. then I cut the vertical lip off of the new pan to fit it back under there and weld it through the spot weld holes previously drilled.
I've documented some of what I've done on the site here just in case it might help others down the road.
click the links and scroll down the pages to where I begin(I have multiple posts through out the process). maybe it'll give you some ideas.
driver's floor pan on my Bronco
driver's and pass floor pans on customer Bronco
