That's the wrong yoke. The 79 Yoke is for a larger 1330 u-joint. I found the actual u-joint measurements.
1310 (Small) - 1.0625" Cap, 3.2188" across
1310 (Large) - 1.125" Cap, 3.2188" across (This is what the EB and 76-78 Full Size uses)
1330 (Small) - 1.0625" Cap, 3.625" across
1330 (Large) - 1.125" Cap, 3.625" across (This is what the 79 Bronco/Full Size uses)
1350 - 1.188" Cap, 3.625" across
1410 - 1.188" Cap, 4.188" across
The problem here is that your driveshafts are the older Borg Warner Type instead of the Spicer type. I don't know if they ever made a CV Yoke for the NP205 that fits a Borg Warner CV. (None of the ones at JBG do, they are all the newer spicer type) The best bet is probably going to be to dig through them at the wrecking yard and see if you can find them. If you want new then you might try Six States Distributing or see if there is a local Driveline shop near you. If you can't find the right yoke you might need to get drivelines made with the spicer CV. If you do then you might consider upgrading to the 1330 (79 Full Size) instead of the 1310.
