Hey Duct Tape, glad it's gettin' all dialed in.
If it's all good, then leave it. But I had to chime in anyway regarding the angle (rotation-wise) of the tie-rod. If you do find, after some more driving, that you still have a little bumpsteer or wandering from a bit of vagueness to the steering, try rotating your tie-rod up a bit.
What you're simply trying to accomplish is to put it back the way the factory had the original one on the '66 to '75 models. You would not have had a point of reference on your '76/'77 "Y" style, but you can see it on an earlier model or in our picture of your linkage on our website here:
http://www.wildhorses4x4.com/product/Tie_Rod_Drag_Link_3way_Adjustable_7677yr
Rotating the draglink mounting pad up a bit will do two things. First it will make your trackbar and draglink even more parallel by raising the lower end of the draglink.
It will also serve to position the draglink in a position that is less prone to causing excess rotation of the tie-rod during steering maneuvers. This isn't always an issue with new rod ends, but once they're worked-in a bit from use, they will allow more rotation. So it's good to help them out a bit with proper positioning of the draglink end.
Both of those can serve to give the steering a bit more of a "direct" feel.
As said though, if it ain't broke, don't fix it! But if you want to play around a bit, loosen all the sleeve clamps (including the draglink) and rotate the tie rod centerlink up just a bit.
