NJB71
I am wondering, I have seen MAF that say for 19lbs and 24lbs? are there MAFs that are dual calibrated? I just realized going back over my ebay history, and I bought just that type....a dual use MAF...i have 24lbs injectors .....
The MAF does not know nor care what size injecters you have.
The MAF (Mass Air Flow) looks at how much air is going into the engine and gives a very precise voltage to the computer. The computer looks at the voltage, then looks at the programming (that matches the MAF output) and then knows how much air is engering the engine. Then looks at the injector size (also a program feature) and figures how long to squirt the injecter.
Your aftermarket MAF works on the old computer "garbage in, garbage out" principal. You lie about how much air is going in and the computer give false outputs on how long to fir the injecters. On a race engine that uses fixed timing tables at full throttle (the A9 series for example) then the computer calculating load is not an issue. But in daily driving where the computer is setting the ignition curve the timing will be messed up. the computer can't accurately calculate the load because it does not have accurate numbers about how much air is enering the engine.
So to have a MAF that can do 2 different injecter sizes is not happening. Not unless you have 2 settings on the computer. Some of the aftermarket chips have a multi postion switch that if programmed correctly you could do such a trick. but at that point you might as well just program the computer correctly and not have the issues.
I have a maf from Aabco they program it for your injector size but you have 10 settings on the maf that you can program yourself with their software. It's a little pricey but if you plan on changing your motor combo you don't have to keep buying a maf for your injector size. It will work on a 5.0 or even the newer mustangs. There is a good write up in 5.0 magazine or just go to AndersonFordMotorsport website they sell it in different sizes I bought a 85mm for $389.
Case and point I'll be running 42lb/hr injectors with my calibrated MAF to a 100% stock Mustang computer.
My Pro-M MAF is calibrated to whatever specific lb/hr injector I am running...
but your idle quality will suck and be rich. at idle the mass air meter does not control the injectors, the computer has a set injector pulse. therefore your 42's will be injecting at the rate same pulse as the stock 19's, dumping twice as much fuel at idle.
a cheaper lightning maf and tune would fix it and perform better.
Your MAF should have come with paperwork that tells you flow values, with that info your tuner can adjust the chip or if you have a Tweecar or Moates Quarterhorse you can do it yourself. You need a wideband to see just where your at tho if your gonna tune it yourself.
whats you motor, bone stock 5.0? If not, get thee to a dyno and have a chip made for your combo.
He asked if there was a dual calibrated maf. I just said I have a maf with available software so you can run different injectors without changing your maf you program the maf tables with a laptop. I did not say anything about the computer or a tune just gave him an answer on his original questionsorry to say this but that is BAD advice for the OP.
with the OP combo it will never run 100% right without a tune. you may get it bearable but that will be about it.
the best advice for him would be to buy a 90mm OEM lighting MAF and find a good custom dyno tuner. NO MAIL ORDER TUNE WILL EVER GET IT RIGHT. i put that in caps for a reason.
with the set up on your motor throwing hack parts at it (dual MAF's etc) will not correct the tunning in the ECM. BW's post sums it up pretty well.
i think i mentioned it before, but if you have some stock 19's put them in with a stock mass air meter and see how it idles and drives. I know yuor engine is not stock but the 19's will be good for about 80% of your power. (dont go drag racing with it). if that runs well, then invest in the lightning maff and a custom tune.
