http://products.pollakaftermarket.c...-valves/light-truck-6-port-motor-driven-valve
6 port valve, the do not exceed pressure is 65 psi
Thanks for the quick response! With the higher pressure 6 way valve where would I install the fuel pump? It needs to be close to the tank as I understand. Would is still make sense to have two pumps in this instance? If so would I need to add a relay and a mechanism to engage one and not the other based on the the toggle switch.
