- Oct 14, 2004
- 5,001
What is that opinion based on?
He stayed at a Holiday Inn Express
We don’t do direct work for customer vehicles at Duff’s. But, my shop is only 30 minutes from the office.
I’m the “Mike” you get when you call Duff’s for technical support. I’ve been there for five years.
I cut my teeth on custom 4-links for Minitrucks and lowriders, beginning in the ‘80s.
If you are interested in having work done, I would appreciate your consideration. Feel free to email me and we can go from there.
You had me at,
"4 links for Mini Trucks in the 80's...."
We must be about the same age.
Yeller, this is the type of vehicle I have experience with.
https://images.app.goo.gl/t4U929raoPFhJmno7
Obviously they are in a perfect world where they can do whatever they want and put the output shaft wherever they want. But I know in these applications, the geometry let's the pinion angle radius match the drive shaft and the plunge is usually less than 1in over 36in wheel travel. They also have perfect antisquat and all that, to where having over a 1000 foot pounds of torque down the driveshaft has no affect or input on the suspension raising or squaring. Drive shaft angle is also almost the same as the lower links. Everything about the duff kit seems abnormal. I'd like to see it performs in a high horsepower application under acceleration and cornering under power
Alright, I ordered it so I'll post pics as I go as well as a review once I get her on the road.
Did you also have a 1985 S-10 ext cab with a SBC? Exhaust note kept the deer
...Exactly.......
You had me at,
Did you also have a 1985 S-10 ext cab with a SBC? Exhaust note kept the deer from the roads.
Well...you got me there:
'83, single cab, with 383 stroker and a TH350...
Best thing about that one...well, two things-
1) I learned about cooling systems!
2) I learned that good brakes were just as, or more, important than the ability to go fast in a straight line!
If I had only known how much that would benefit me when I started working on Broncos!!!
'87 Extended Cab
At 17 I pulled the V6 with only 66k on it. I put those miles on it in just over 16 months driving back and forth from Orlando to Jax Florida.
While it still looked new it had a,
350 sbc
TH700 OD
I learned how to do really long burn outs....lol....
She was an insane tire spinner!
Used to put a few bags of concrete in the right rear corner of the bed. It made a remarkable difference for only about 160 pounds.
I cut my teeth on that shit.
Loved every damn minute of it.
My parents and my S-10 were not friends, lol.
My poor eb was relegated to daily driver status back then...lol.
Haha!
I took the stock rear bumper off, built "boxing plates" for it, filled it with three bags of Quikrete, welded it up, and bolted it back on. Ran 295/50/15's with 4" dropblocks and a steel bedcap... It would make white smoke and black lines. I tried putting Lakewood "slapper bars" on it...but it was so low that I couldn't get over a speed bump without them digging in.
I had a .292/.480 Lunati "Street Thumper" cam in it. It had NO vacuum. Couldn't stayed stopped at a red light unless you popped it into neutral or park. It would pull right out from under its own brakes...
I bent up a "roll cage" out of exhaust tubing, painted it black, and put black PVC pipe insulation from Sears on it...just so I could mount five point race harnesses.
I was able to do it all for under $5k, in 1996. First set of Flowmasters I ever owned. Took me 17 evenings and two weekends to do it. Back then, there were no "V8 swap kits". Of course, we walked 5 miles to school, uphill both ways...too!
Jason - I'm looking forward to seeing how your 4-Link turns out.
I see you mounted the Rear Coil Buckets even with the Top of the Frame. What springs do you have up front? Soft Top or Hard Top? Bumpers? Drivetrain in now with body installed?
Did you mount the rear buckets at the Factory 92 Inch Wheel Base or slightly farther Back?
Great pictures by the way.
