Duff Arm Hitting Frame
o2bnmud
Yep, they will hit the frame. I've got 2 dents in the frame from some unexpected dune jumping.
Tony
Apogee
Tangent, OR
Your signature line says you have a D60 rear and HP D44 front, so are you running stock width axles or full-width. If full-width, are the wedges located at the factory width or spread wider at the F-150 width or something else? If wider, I wouldn't think you'd have any issues with frame interference. Otherwise, set your bump stops accordingly.
rcmbronc
Tomah WI
On my Cage arms the tube hits the frame just about the same time the front end is fully compressed so I would say to just adjust bump stops to avoid both contacts
E
EricLar80
My axles are EB width.
E
EricLar80
Isn’t it bullshit that they hit? Why didn’t they lower the bracket to avoid this?
Yeller
Rogers County Oklahoma
Then the bracket would drag even more when wheeling, they hit all the time as it is. Bump stops are an important tuning tool, your shocks will thank you.
also remember these were designed for 5.5" lifts and now we're putting them on 2-1/2" lifts.
E
EricLar80
Thanks for the link Mark. Do you TIG weld by any chance?
I'll end up going with a custom frame bracket, in fact I have some materials on order. I want to run a Johnny Joint, and the stock bracket from Duff is kinda lame. I have a Miller 211 and 220V in my garage, but TIG looks so much nicer...
Eric
toddz69
The Weldtec brackets in the link are what the brackets in the RDC thread (one of John Cole's trucks) have evolved into.
Todd Z.
toddz69
What is RDC? Do you have a link?
RDC = race-desert.com. I was referring to the link in your first post.
I like those brackets but not the price. I have something similar for my Lars Bars except they cost about $35 ea. from Poly Performance. They don't have the speed holes in them but otherwise they're perfectly functional.
Todd Z.
E
EricLar80
Ah, I see... thanks for the link, Todd.
Here is what I am building. The bearing surface for the bolt will be quite a bit thicker than stock, and welded to fit the johnny joint width.
Monster Mike
Eric, great question.
As others have mentioned, unless you're jumping your Bronco or have less than 3" of lift it's been our experience that it's very unlikely JD long arms will hit the frame.
To answer your question as to why the brackets aren't longer. As mentioned we originally designed longer arms for slow rock crawling. The bracket is tucked up as high as possible so it won't hang up on trail obstacles. You can imagine the 1,000's of customers we've sold long arms to that wheel in the rocks and wooded areas that if they had inch longer brackets they'd be cursing us every time they wheel because the darn brackets would hang too low and catch on everything. Then the other major group that buys these arms are street cruisers who just want a nice smooth ride. Their biggest concern beyond that is color matching the arm to their frame or body. Then there is a smaller group of ppl that enjoy the long arms for recreational fun that they weren't originally designed for like going fast in the whoops or jumping in the sand. That's when you may experience this. We've found that most of these guys aren't beating their bronco's like a rented mule so the majority of them still aren't experiencing this which is typically how hard you have to run them to hit the frame. I hope It's easier to understand now why no changes have been made. it's not that we are against change we just need to see more ppl like you speak up so we know it's time to do so.
By the way, a good amount of product testing is done with our own vehicles. The Pony express runs long arms with 2" coil springs and standard duff long arm brackets. we have yet to hit the frame out on the sand dunes and she has taken several hard whoops at speed.
Thank you,
Michael Duff
KyleQ
I beat on mine like a rented mule and I'm really surprised that I haven't had any failures with my long arms. They are tough SOB's - I've got them for two of my vehicles.
deepseahog
Newbury Park
also remember these were designed for 5.5" lifts and now we're putting them on 2-1/2" lifts.[/QUOTE]
I just went onto Duff website and read the instructions which stated they are made for 3.5" to 5.5" lifts (not 2.5"), and mine is 3.5" and they contact the frame on full compression.
