I am installing a 3.5" lift with Duff extended arms. I am wondering where to start with radius arm bushings for pinion angle. I will cut and rotate the knuckles for caster but I am just looking for a starting point for bushings. 4 degree, 2 degree or 0?
Ugh, You won't like this...
If you are going to do the caster correction, then you want to use the wedge bushings to establish the correct pinion angle. Factory was 8 degrees, and that was correct for a low pinion Dana 44 with factory radius arms. The long arms swing thru a different arc than the Dana 20 driveshaft. So as the suspension cycles, the relative angle between the driveshaft and the radius arm is different. Which means that your front pinion angle will only be exactly correct at one and only one suspension height. You want your front axle u-joint to be in perfect phase and alignment when it is rotating the fastest, and the longest. (which is typically at static ride height, fully loaded, at 65 mph on the highway) It's only a few degrees, and many will tell you it doesn't hurt anything. But of course there is the "right" way, and countless wrong ways to do this.
The other problem is that countless people order their suspension first, and then decide to modify their drivetrain later. You really do want to know your transfer case output location and get it locked down. If you set your pinion angle for the Dana 20 in the factory location...don't come back to me next month and tell me you decided to add a 5 speed, or swap to an Atlas, or clock your transfer case. You get one chance to get this right. Because once you "find" your pinion...that will determine EXACTLY how much you will cut and rotate your knuckles. Again, I am talking about a few degrees, but that matters when it's time to set your caster.
I happen to like Jim Cole's long arms, (Duff arms) and I usually do them with an Atlas, clocked up tight against the frame. I think I ended up with 14 degrees of pinion and 7 degrees of caster on the last one. In order to get the pinion right, I had to go with 4 degree bushings...but install them upside down.
So first things first (always...) MEASURE the suspension height gap between frame rail and axles. Front and Rear. You said 3.5 inch lift, so we are looking for 9.5 inches and 10 inches. Hang a protractor on your front driveshaft, and measure your driveshaft angle. hang a protractor on your pinion and get a pinion angle. (this part of the process doesn't care which radius arms you use...if any.) Keep in mind that your factory track bar is going to fight you to get the pinion right. If your Bronco is a project, and doesn't have all of its weight on it...then cut some wooden 4x4 gage blocks and strap it down.
Note that this is the ONE TIME where cutting wedges and re-welding might have some benefit. But at 3.5 lift, please DON'T. I would compromise a couple of degrees of u-joint angle to run a standard 0,2, or 4 degree bushing. So if you have to run a 2 degree upside down to get your driveshaft right...OK.
I just thought of something. WHY do you want to know this? Do you have any intention of installing the long arms and then doing your cut-n-turn later? Please understand that if you install your long arms and set your pinion correctly...your Bronco will be un-driveable until you do your cut and turn. Wierd and unstable things happen as you cycle thru zero caster. So don't even think that you are going to install long arms without doing the caster correction at the same time. That's just silly.
Have fun!
