Duff Arm Hitting Frame
deepseahog
Newbury Park
Eric, great question.
As others have mentioned, unless you're jumping your Bronco or have less than 3" of lift it's been our experience that it's very unlikely JD long arms will hit the frame.
To answer your question as to why the brackets aren't longer. As mentioned we originally designed longer arms for slow rock crawling. The bracket is tucked up as high as possible so it won't hang up on trail obstacles. You can imagine the 1,000's of customers we've sold long arms to that wheel in the rocks and wooded areas that if they had inch longer brackets they'd be cursing us every time they wheel because the darn brackets would hang too low and catch on everything. Then the other major group that buys these arms are street cruisers who just want a nice smooth ride. Their biggest concern beyond that is color matching the arm to their frame or body. Then there is a smaller group of ppl that enjoy the long arms for recreational fun that they weren't originally designed for like going fast in the whoops or jumping in the sand. That's when you may experience this. We've found that most of these guys aren't beating their bronco's like a rented mule so the majority of them still aren't experiencing this which is typically how hard you have to run them to hit the frame. I hope It's easier to understand now why no changes have been made. it's not that we are against change we just need to see more ppl like you speak up so we know it's time to do so.
By the way, a good amount of product testing is done with our own vehicles. The Pony express runs long arms with 2" coil springs and standard duff long arm brackets. we have yet to hit the frame out on the sand dunes and she has taken several hard whoops at speed.
Thank you,
Michael Duff
I understand that these long arms are made for slow speed rock crawling, which is what I mostly do, but every now and again I may be in a sand wash at speeds around 25-30 and come across a whoop, which has caused my arms to contact the frame pretty good. I run a WH 3.5" coil up front, but I also have a heavy Warn winch on the front bumper. Maybe I need to look into Nitrogen filled bump stops. Not a lot of those that I've found for a EB.
68ford
Just keep hitting larger bumps until the full self clearancing procedure is complete 😂
68ford
There is a lot of leverage. It may tear the radius arm brackets off the frame of the radius arm doesn't flex.
Monster Mike
Is there anyone here that has had this issue running Duff coil springs? I'm not counting the guys that go full on pre runner and huck their Bronco's. If you do that you need different mounts and you should be running hydro bumps.
One thing to keep in mind you can design a coil spring several different ways. This can change the fully compressed height of a coil significantly. We haven't tested our long arms at full bump with WH coil springs so maybe there is a big enough difference there causing this problem?
For example, our 2.5. 3.5 and 5.5 coil springs are all made out of different thickness of bar. When I first brought the 2.5" lift back a couple years ago I tried using the same bar thickness as a 3.5 spring. It was a bit stiff so I swapped to a thinner bar and we had to change the weight of the shipped coils in a box by 9lbs less!
With so many factors that make up a coil spring it may very well be the other vendors spring accentuating the issue.
MM
68ford
Obviously it is a very small percentage of people that will have this issue. That being said, I don't think coil bind should be the compression limiting factor when designing a radius arm. It should have been a constant such as the stock oem bumpstops. Make the radius arm just not touch with a factory bumstop shortened half an inch to compete a hard hit. In 99.9999,% of cases the axle should not go up past the factory bumpstops. Yet it should be able to go to the factory bumstop because people should be able to get all possibly up travel. What about the guys who want diff arms but run coilovers? One would assume use the OEM bumpstops and get the most up travel. If not, they should be sold with bumpstops to keep this from happening that are the right length so the customer doesn't have to play testing with different length bumpstops.
Monster Mike
Keep in mind when these were designed they were tested with a forklift or a RTI ramp. Coil bind when articulating one corner behaves differently then compressing both coil springs at the same time. Using coil bind as your limiting factor when rock crawling is perfectly acceptable. In fact most times you will bottom out the springs before ever hitting the bumps at all with a 3.5-5.5 suspension lift.
when it comes to jumping whoops at the sand dunes you definitely want to set them up to limit with a bump stop before coil bind. From the beginning, JD Long arms were not designed with that recreation in mind. For the few that want to jump their Bronco's with long arms we definitely advise that you take measures to set your Bronco up so it can handle that.
It's also fair to point out the coil springs of 15+ years ago from all vendors have changed/gotten better which means the overall compressed height could have been altered as well. I'm not saying that is a fact just good to point out as a possibility and a potential reason why some experience this issue while others don't.
MM
5001craig
I had my front tires off the ground around 2.5' in the sand when the dunes were really peaked and I had to hit it a little hard to get over. Bumps did their job and the Duff long arms never contacted the frame.
I agree with MM--if you are airing-out the bumps need to be set-up correctly. In my particular case, the Duff long arms are not my major concern. My track bar/oil pan real estate is however...
Dlish
I have Duff 3.5 springs and the long arms. And some crappy blown out rubber bump stops
Def have had the front wheels off the ground and not had an issue of arms hitting the frame. Grabbed a couple of screen shots from a video coming a little hot outa a mud hole, full suspension drop and tried to get a shot of the lowest the front end went after hitting the ground. Springs do a great job of absorbing without the arms hitting the frame.
I bet desert woops would be faster and higher than this example, but chalk me up as another guy who tries to beat the piss outa Duff parts and haven't had an issue.
TonyPDX
I used Bilstein bump stops to make sure this would not happen, but I noticed it was a possibility when I was originally setting up the front suspension. They really don't limit the compression travel in the real world, just use some sort of bump stop... I did self-clearance the oil pan, however....
