dave67fd
- Sep 24, 2010
- 2,864
Hey Guys,
Just planning on some of my frame componenets and have a couple ?'s
Duffs Stage 1 shock hoops use a C frame bracket which bolts on from the top of the frame rail through to the bottom. Can i assume these clear the clutch frame linkage bracket? By the pic it just looks close.
The Duffs rear axle bump stop has a bracket (purchased seperately) that is designed to attach to the OEM bump stop bracket not the frame correct?
If i am cutting off my bump stop mounts is there any reason i can't just attach (drill/tap) directly to the frame or do i need for whatever reason to weld on a new bracket for the stops to mount to. My stock OEM bump mounts are questionable.
