Dynamic tire balancing
casadejohnson
Bronco Alchemist
I know it's been discussed before but I was thinking about trying something a little different. I was planning on using the Airsoft BB's but I was talking to a couple different guys I know who drive semi's and they said that Antifreeze is another common way to balance large tires. The biggest advantage I can see is that it would be a lot easier to put it in because it would go through the valve stem instead of having to break the bead on the tire to install Airsoft BB's. The disadvantage would be pissing off the tire guy when I buy tires next time.
Any other reason not to try it?
burntfish
ouray, co
If you get a flat or bust a bead on the trail. What if you get a nail and start lossing antifreeze in your drive way and a animal or kid gets to it. I love the airsoft in mine and they are not that hard to put in.
JohnJohn
Richmond
Or you could buy real tire beads like Dynabeads. They can be added to the tire through the valve stem.
I am running the Dynabead offroad larger version that cant go through the valve. They are a bit smaller than a bb.
Zillacon
Hackin Away!
I have not had good luck with the Dynabeads. They tend to gather static elctrcity and stick in bundles of the inside of the tire. I'll try and dig up the pick of mine where I had to beat the tire with a hammer and shop vac them out. Airsoft are better or get some Centramatics, thats what I did and they work killer.
Zillacon
Hackin Away!
Found my pic of the Dyna beads. This was on brand new 37" MTR's. No moisture anything, just staic electricity. It was driving me nuts as it was sporatic and wouldnt do it all the time so I pulled one beadlock apart when it was happening and here is what I found. Had to beat the hell out of the tires with a rubber mallet and shop vac them out.
Here is what _ went with. A little pricey but I never had one issue with them and my tires always wore evenly.
http://www.centramatic.com/Page.aspx?page=Demo
I got mine from Dave at Northridge4x4.
casadejohnson
casadejohnson
Bronco Alchemist
Thanks for the info. I had not seen Centramatic. I did some mild wheeling and I think I have some issue with the tires spinning on the wheel a little when aired down. At least that would explains my tire balancing problem. I have had the tires balanced with weights twice in the past two months and both times they were way off.
Zillacon
Hackin Away!
I thought I had the same issue. Get a white grease pen and mark your tires/rims on the backside to see if they move.
