Make sure that your slip shaft is working properly. If its not sliding, then its putting a lot of pressure on the u-joints everytime you hit a bump.
Tom
I have the same issue (pinion Angle) with a 2.5 lift...Why is it "they say" 90 percent of the broncos with 3.5 and lower don't need it? I challenge that statement!! I belive you can get by with out correcting pinion angle but it should be corrected!! What say you?
I have a 5.5 lift, and a 4 degree shimm was enough. put on one of those aa output shaft housings (1.3 longer than stock) and started eating u joints, lots of vibration when on the throttle. gonna try and put the 4s back in also an see what happens
I bought the angle guage at Lowes a few weeks back. It said I was 6 degrees out, but it looked like there was a little gap at the back of the springs. So I bought a deep 3/4 inch socket for 1/2 drive and cranked on it some more. Got it down to less than 1 degree.
Tom
