Well, I took the plunge last week and ordered the E-Street EFI system from Edelbrock. I should get delivery in the next couple days, but I will post pictures and try to include as much details as possible with the install.
I chose the Edelbrock E-Street system with the Sump Tank/Pump fuel system. (EDL-3606) This fuel system requires NO modification at all to your existing fuel system prior to the Mechanical Fuel Pump. Just re-route the outlet side. The Mechanical Fuel Pump sends fuel to the Sump Tank, which acts like an Accumulator too, which has a high pressure fuel Pump inside that pumps High Pressure Fuel to the Throttle Body. This fuel system can be purchased separately and will work with other EFI systems as well.
With minimal fuel system changes from the start, going back to stock is VERY easy too if desired. Also, you can still use both Stock fuel tanks and the Original Selector Switch as well. None of the original fuel system has to be changed.
Everything from the directions seems pretty straight forward with the required input to the Tablet included. Input your engine info with a few prompts, get everything installed and ready for start-up and get her going. The computer "Learns" what your engine requires and adapts from there..... That's what it's supposed to do anyway.
Let's see how it goes. I'll keep you posted.
